did i contaminate the coolant????/my temp going to 3/4
Old Nov 5, 2009 | 08:12 PM
94Z28LS1toLT1's Avatar
Unhappy did i contaminate the coolant????/my temp going to 3/4
hey injuneer i think i have an idea why my temp goes to the 3/4and when it goes to thye middle of the gauge it will climb back up pretty fast when sitting in traffic or at a lite.so..when one of my hoses came undone one day and all my coolant was gone. idk y that happened, my wife got me two gallons of the dexcool the do not add water one. when i put both of the gallons in the car needed more so had to put the rest with water is it possibel that i messed up the coolant???i spoke to sum1 named rudedog and his 95 Z28 doesnt go higher then 185.also when i drive the car in the morning its around 60 degrees outside, and its kinda cold outside when i warm up the car for like 10 minutes the temp is lil bit above the 160 mark of the gauge then when i leave the gauge would stay cool as im drive the temp wont climb up.by the time i get to work which is like 15min drive the mark would be a lil bit above the middle of the the gauge. does the weather affect the temp of the car should i flush the radiator out and drain and fill up with the normal coolant (not the do not add water one)cuz could the contaminated coolant be the issue. thank u man.
Old Nov 5, 2009 | 09:12 PM
moparman's Avatar
The ambient temperature deos affect how hot the engine gets. Car will run cooler at 30 degrees than at 90 degrees.
Old Nov 5, 2009 | 10:20 PM
shoebox's Avatar
There won't be any "contamination", but you might want to check the strength of the mixture with one of those simple indicators you can buy.
Old Nov 6, 2009 | 05:31 AM
Yep.... you diluted the freeze protection and the boiling suppression, by adding the water. But it didn't affect the coolant's heat transfer properties... except to make it better, since water is a better coolant than ethylene glycol.
Old Nov 6, 2009 | 05:26 PM
Question draining/filling
should i drain all the liquid out and use a different coolant..and if ido wats the coolant brand i should use and wats the best for my car. thank u.basically wat do u recommend?????
Old Nov 11, 2009 | 08:50 PM
Red face my temp
my temp stays between 210-235 at normal speed cools down when im cruising air dam is in place and not running hot so im guessing the camaro is Fine.......! too thanks everybody!!!!!!!!
Old Nov 13, 2009 | 05:42 PM
84zed's Avatar
Did you bleed out any air.I don`t know if that would do it or not?
Old Nov 19, 2009 | 07:32 PM
yea i got all the air out after i get done driving the car i dont hear and hissing like air trying to escape or boiling..when i loosen the bleed screws no air comes out so im assuming all the air is out.wat does ur temp stay at???
marlar98
Oct 21, 2015 02:02 PM
tdigger9899
Sep 7, 2015 10:56 AM
Pwilson59
Sep 3, 2015 08:47 PM
Aug 7, 2015 01:26 PM
Noct
Jul 14, 2015 01:18 AM
