LS1/6 swap into 95z28
Old Nov 5, 2009 | 07:31 PM
tanks14's Avatar
Im thinking of doing a LS1 or 6 swap into my 95 z28. All i would like to know is what would i need to do it, and how much would it cost? Aside of the motor, i know its going to be a few grand. Any help would be nice.
Thanks in advance.
Old Nov 13, 2009 | 07:34 AM
Antz97ZNJ's Avatar
Your looking at atleast 3-4 grand.
Old Nov 15, 2009 | 08:31 PM
reamo04's Avatar
k-member, can be found used for 50, or 400 or so for a tubular
motor mounts - 150 for spohn solids
if you are using a lt1 4l60e you would also need the flexplate spacer which is around 50 IIRC
The wiring harness you can get with the motor, along w/ the computer, etc.
Its really a pretty straight forward swap IMO.
Old Dec 12, 2009 | 07:17 AM
killpro's Avatar
would an ls1 hook straight up to a t56 in a 94z28? Would you have to change anything in that area?
Old Dec 12, 2009 | 02:22 PM
camaronutt's Avatar
Im pretty sure they are not compatible. The clutches and input shafts are different. Sell the t56 you have and try to find a LSx/6 speed combo for sale instead.
Old Dec 13, 2009 | 03:23 PM
reamo04's Avatar
the LT1 t56 cannot be used, but an LT1 4l60E can be.
Old Dec 13, 2009 | 04:36 PM
bkpliskin's Avatar
Can it really? Because that would make me very happy since I'll be ordering my Level 2 Performabuilt this spring. And I have yet to decide if I want to build a turbo 355 LT1 next or use an LQ9 block and go from there.
Old Dec 13, 2009 | 07:05 PM
reamo04's Avatar
yes, you just need a flywheel spacer. Part from hughes is HUP-HP3750 if i remember correctly. I have one laying in the garage I can double check wednesday or thursday
Old Dec 15, 2009 | 05:55 PM
96flame's Avatar
The 4L60E needs to be 95 or newer because they switched to pulse width modulated torque converter lock up.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
