oil pressure drop
Old Oct 24, 2009 | 06:44 PM
98Zragtop's Avatar
oil pressure drop
My 1991 RS with 305 engine and 130,000 miles has started to show low oil pressure at idle. When the engine is cold and the rpm's are up, or when you are driving, the pressure seems okay, but once warmed up and at idle, it is very low. I have checked and the oil level is not low, and have not noticed any unusual sounds or rough idling. I want to keep this one running a while longer, but don't want to put a lot of money in it. Any suggestions as to diagnose the problem? I have never had any problems with engine prior to this.
Thanks for your help.
Old Oct 25, 2009 | 12:23 PM
mikey dragster's Avatar
A cheap oil PSI booster is run a heavier oil. . .
if you got 3w-30 or 10w-30 now go to a 10w-40 if you have a 10w-40 go to a 20w-50. . .
I ran 10w-40 during the cold months of the year and 20w-50 during the hot months of the year and i got 193K miles of of my third gen then i decided to build it up. . .
Mike
Old Oct 27, 2009 | 05:54 PM
98Zragtop's Avatar
Thanks for the suggestion, but it turned out to just be the oil pressure sensor. Put in a new one and everything is fine.
Old Oct 27, 2009 | 06:04 PM
Very cool good to hear all is well . . .
Mike
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
