383 stroker kits.
Old Oct 19, 2009 | 10:51 AM
Conez's Avatar
383 stroker kits.
im just kinda humoring the idea of stroking my lt1. anyone know some legit prices for some kits?
Old Oct 19, 2009 | 11:41 PM
95Blackhawk's Avatar
Bought my first one for $1100 incl pistons, rods and rings. I would not go this route again and my 2nd 383 was all forged but bought the engine built so cannot comment on costs.
Old Oct 20, 2009 | 10:46 AM
Conez's Avatar
would it pay off more to stroke an lt1 or get like lt4 heads and intake? both?
Old Oct 20, 2009 | 12:08 PM
Mikes 1994 z28's Avatar
You would have a much bigger gain by doing heads and intake then just a stroker kit unless you're going forged and going to spray. A stroker kit alone will not net much of a power increase unless you get good heads that flow.
Old Oct 20, 2009 | 01:32 PM
ReaperWS6's Avatar
Stroker kit + AFR 195cc heads? What would that net you? Would the CC506 cam be too small for that setup?
Old Oct 20, 2009 | 01:48 PM
97WS6SCharged's Avatar
A hefty credit card bill.
Old Oct 20, 2009 | 09:38 PM
MikeGyver's Avatar
Stroking the motor and not changing anything else will probably do nothing at all. You'd be Far better off getting good heads.
Old Oct 21, 2009 | 10:15 AM
RamAir95TA's Avatar
95% of the power is made in the valvetrain, not the rotating assembly.
Old Oct 21, 2009 | 11:55 PM
Your final HP no's will be based on the cam selection. We cannot say if that cam is too small or not. It depends upon your usage.
I am an example:
My first 383, I wanted simple tuning so I went barely over stock. That was a serious stump puller but died after 5500 rpm. Next, I went into road racing and so built my 2nd to make power all the way to 7K. ON this second one, I made less power below 3500 rpm but don't care because I am never in that zone while racing.
Old Oct 22, 2009 | 10:30 PM
Meen95z's Avatar
$1600 for forged 383, 395, or 397. Competition Products catalog.. Comes with Howards american 4340 crank, 4340 6" h beam rods, and hrc or srp forged pistons, file fit moly rings and tri-metal race bearings.. I recommend it, better than eagle or scat in my opinion..
Old Oct 23, 2009 | 04:57 AM
ReaperWS6's Avatar
Sounds pretty good. What would be an ideal cam for mostly street use but race duty here and there? Custom grinds seem to be the way to go these days.
Old Oct 23, 2009 | 11:14 AM
Conez's Avatar
what would say about these for more power?
http://www.jegs.com/i/Edelbrock/350/61909/10002/-1
http://www.jegs.com/i/Edelbrock/350/7107/10002/-1
http://www.jegs.com/i/Edelbrock/350/3809/10002/-1
Old Oct 23, 2009 | 12:24 PM
RamAir95TA's Avatar
No, no, and yes. Their intake manifold is no better than the stocker.
For heads/intake, seek out www.advancedinduction.com and have your stock castings worked. Others will recommend Lloyd Elliott. The 58mm throttle body is always a good idea.
Old Oct 23, 2009 | 05:46 PM
Cook Performance's Avatar
www.cpengines.com
We have the best engines around for the best deals!
Check us out.
Thanks
Jake
317-697-6061
Quickss96
Jan 29, 2016 05:56 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
