QTP Electric Cutout
Old Sep 14, 2009 | 04:31 PM
96SSIndeed's Avatar
QTP Electric Cutout
Ordering my cut out for my camaro and saw there electronic controller. I know i don't need this but it got me wondering. When i open the cutout, i have to hold the button until its all the way open? then hold it until its all the way closed?
Thanks Chris
Old Sep 14, 2009 | 04:40 PM
mzgp5x's Avatar
I have run a QTP 3 1/2" Single cut out on a Mufflex system. Installed before the kick over the axle. I only have the low cost switch option. It is OK, but you do not want to hold it and drive it open or closed due to extended current draw. It is fused. With engine off (Ign ON) I listen for it to load up full closed or open position. Or, with engine on the noise will reduce and I will stop. I did notice the screws do come loose and I usually re-torque @ least once during the year and clean the carbon from the disc seal. It really helped with the flow, but alot of noise. app... 97ss 383-D1 MM6. B.
Old Sep 14, 2009 | 04:58 PM
96SSIndeed's Avatar
thanks, for the input
Old Oct 9, 2009 | 02:18 PM
transamguy77's Avatar
Something else you may try are the DMH Performance electric cutouts
http://www.dmhperformance.com/ecutout.htm
Old Oct 26, 2009 | 07:16 PM
fastfox's Avatar
hold it a few seconds after u hear it get louder and the same when u close it.
Old Oct 27, 2009 | 10:20 AM
wrd1972's Avatar
You dont want to hold the switch in an on position any longer than necessary. There is a great deal of gear reduction in the gear boxes and the gears, bushings are going to be stressed or torqued once the blade hits full open or closed and the power is still on.
This is what I did on my cutouts. Go to radio shack and get a pair of 50 ohm 10 watt resistors and put them PARALLEL on the 12v power wire for the cutouts.
The resistors will reduce the power going to the switches and ultimately the cutout motors and not cause them to be stressed once the are full open or closed. The resistors will also ensure that one they fully close, that the motor and drivetrain do not "rebound" or "recoil" and cause the blade to slightly crack back open.
The resistors will also cause them to open and close much slower than before, but they will work much better and last much longer. I have never understood why the manufacturers dont do this.
Old Oct 29, 2009 | 11:16 PM
onefastmx5's Avatar
I wired mine off of the cigarette lighter, so the key doesn't need to be on. Easy to hear when the motor stops.
My DMHs are already leaking after 3 weeks!! There appears to be a rubber o-ring in there that seals the valve when shut and it keeps poping out. Very annoying to hear these things leak when closed. Go figure, with this economy you can't get a "quality" product anymore.
Old Oct 30, 2009 | 12:20 AM
Moshbmx1's Avatar
Ive been running my DMH for a year and a half now and I havent had any leaking problems or screws backing out. My brother has been running dual low pro DMH's on his GTO and he is problem free as well. I know my buddy has a QTP on his third gen and he has had the problem with the screws backing out, must be a common problem. Granted I have only put roughly 400 miles a year in the past 3 years on my Camaro so mine doesn't see much road time
Old Oct 30, 2009 | 07:33 AM
onefastmx5's Avatar
I know alot of people have had success with DMH and supposedly the QTP was known for leaking, but I was very unpleased to see carbon on the outside of the butterflies. Granted, I have opened/closed about a dozen times in a few weeks- maybe they just not meant for that much use?
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
