changing wheel offset
Old Sep 7, 2009 | 08:30 PM
reamo04's Avatar
well, have some wheels that stick out on the front maybe 1/4" or so, so about 6 mm. Now, the backs fit PERFECT, sit about flush with the fender, or maybe in a little bit, and the fronts are pretty close, but it just looks awkward.
Now I have a local machine shop that has widened and narrowed wheels for me, but they always do it from the back. I have yet to call them to see if they could narrow it a little from the front.
Otherwise, I have heard of milling down the wheel hub (where it bolts on) a little bit, these wheels have HUGE hubs on them so machinining them down should not be a big deal and still keeping the wheel integrity.
Anybody have any experience with anything like this? My other option, (i have seen it on some highly custom mustangs used for drift), is to find a way to shorten the front suspension a little bit to bring everything in a little further.
Old Sep 10, 2009 | 04:41 PM
bluz28's Avatar
Get a set of aftermarket upper A-arms, then get it re-aligned. If the alignment shop set the camber to your previous settings your front track will narrow at least 1/4" per side, or probably more.
http://marylandspeed.com/umi-perform...11-p-2534.html
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
redzed
Sep 4, 2002 06:22 PM
