Rev Kits. Need some opinions.
Old Jan 19, 2003 | 11:21 AM
Smokn '94 Z's Avatar
Lightbulb Rev Kits. Need some opinions.
I already tried in the LT1 Tech & someone said to post here:
When I install my GTP Stage 2 heads I am probably going to run a AFR Rev kit if $$ is there. I was wondering if I should make an effort financially to get the kit or if I will get by with out. I know I can keep it from reving higher but I kinda do want to play with the shift points & rev limiter so I may get it spinning up there..
Opinions appreciated...
Old Jan 19, 2003 | 03:08 PM
Mindgame's Avatar
Here are a couple threads that came up recently on this subject. Lots of great discussion on valvetrain and rev-kits. Good luck.
http://web.camaross.com/forums/showt...threadid=65419
http://web.camaross.com/forums/showt...threadid=64134
-Mindgame
Old Jan 21, 2003 | 09:53 PM
Thumbs up
Thanks a bunch Mindgame. I did a search but it seems it always comes up with nothing for any topic I try to search for.
Thanks again. I will go with a AFR Rev Kit.
Old Jan 25, 2003 | 08:59 PM
keven's Avatar
You might run into piston speed and G's before you get too high on RPM's. With cast pistons that can be undisireable.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
CARiD
Jul 7, 2015 08:19 AM
