Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
LT1 Dyno Tuners in So Cal
Old Aug 27, 2009 | 04:19 PM
Wild1's Avatar
I've called Haddad Motorsports 2x and have left messages. Yesterday they didn't call me back. Today, they said they got my message... said they would call me back... no call.
Is there a reliable Dyno Tuner for LT1s in So Cal?
Old Aug 27, 2009 | 11:18 PM
ponyackn's Avatar
just saw that SP motorsports is doin lt1's in a thread on ls1tech. But idk with all the drama they've appeared to have when i read all those threads...
Old Aug 29, 2009 | 12:19 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
What year LT1? I can do 92-94's with the 12-pin OBD1 ALDL port. I dont have the adapter to do the 95-97 16-pin OBD2 ALDL port.
Old Sep 3, 2009 | 12:01 AM
henryz28's Avatar
I have had a hard time finding someone familiar with the LT1 to tune my 1996 z28 also.
Old Sep 4, 2009 | 09:45 AM
Wild1's Avatar
I got a response from Haddad. It takes a while to get a hold of them, they did a decent job before which is why I'll give them another shot.
The Camaro is a 1995. Kevin, I may have a cable since I used to read the ECM with Freescan. If all fails with Haddad, I'll contact you and set something up. Do you need a dyno? Do you work with the factory O2 or do you tune with a 5v Wideband?
Thanks.
Old Sep 7, 2009 | 12:01 PM
Kevin91Z's Avatar
I dont have my own dyno but there are several dyno shops around that we can go to.
I do have a wide band O2 sensor.
Old Sep 7, 2009 | 02:40 PM
Wild1's Avatar
Kevin, Thanks. I do have Sept 11 set up with Haddad. However, if that falls through, then I will definitely contact you. Thanks again. I have to be in Vegas on 9/16 for a run so it needs to be tuned up before then. Phew! Not much time.
Old Jan 21, 2010 | 12:35 AM
Wild1's Avatar
Kevin, it looks like your skills could be of some use. I sent you a PM/email.
Let me know if you are still up for a dyno tune. We could go rent a dyno.
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
383TransAm
Parts Wanted
Feb 15, 2015 05:05 PM
tubby
Oct 13, 2003 09:16 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
