Is the speaker wire length important?
Old Aug 27, 2002 | 10:42 PM
$hawn's Avatar
Post Is the speaker wire length important?
Does the length of speaker wire matter or make any difference, if so would you want it to be longer or shorter?
93 Z28 Patriot Red A4
Old Aug 27, 2002 | 11:00 PM
NineSevenWS6's Avatar
Doesnt matter....
Old Aug 28, 2002 | 12:10 AM
eyeoutthere's Avatar
You don’t want an excessive amount of wire because it will increase your chance of interference. Just use what you need.
Old Aug 28, 2002 | 06:05 AM
LS1 RULZ's Avatar
Speaker wire doesn't pick up noise like an RCA cable can.
Old Aug 28, 2002 | 08:28 AM
megabass's Avatar
The length isn't as important as the size of the wire.
Old Aug 28, 2002 | 09:09 AM
97FormulaWS-6's Avatar
Well, look at it this way.... every wire has a resistance per foot, that means every foot you add in length will add X ammount of Ohms. Typically in speaker wire it's very small but can add up, especially with High power systems, and too small wire.
If you have large enough wire for your speakers the length doesn't really matter that much.
Mike
1997 Formula WS-6, 1 of 473
Mods: P&P MAF, Pro-5.0, SLP LT4 Clutch, 200 Amp Alt, TB Bypass, !AIR, !CAGS, 160 therm, CSI WP, PS Cooler, GMS STB, Cutout, TCI LineLock, ES Swaybar/Trans/TA Bushings, 5%R/20%S Tint, Painted Calipers, Custom Clear Tail Lights/Corners
http://camaroz28.cardomain.com/id/97formulaws6
Rod Bender
Jan 1, 2015 03:18 PM
nothingeined
Aug 10, 2002 07:53 AM
Evilfrog
Aug 7, 2002 11:36 PM
DarkHorse
Aug 1, 2002 04:59 PM
CobraEatr
Jul 29, 2002 11:46 AM
