need helps guys
Old Apr 26, 2009 | 07:47 PM
spr203's Avatar
need helps guys
got a 93 last week the fuel pump quite so i repalced it with a delphi 225 once in it started rite up but when i drove it it would dont run no power like it was lean . replaced fuel filter still no better . check pressure got 45 at prime and at running . have i missed something ? all help would be great . oh btw no check engine lite on . thanks
Old Apr 26, 2009 | 11:08 PM
Check the fuel pressure on the road, at max RPM/WOT. It should hold at least 40psi under those conditions.
With the engine at idle, the only time you should see 45psi is with the vacuum line off the fuel pressure regulator. With the vacuum line reconnected, pressure at idle should drop about 6 to 8psi. Sounds like your vacuum compensation line might not be connected.
Old Apr 27, 2009 | 08:39 AM
spr203's Avatar
ok fix the fuel pressure problem , but still has no power in fact in park if you just stab the gas it falls rite on its face . before the fuel pump went it ran fine .
Old Apr 28, 2009 | 08:37 AM
spr203's Avatar
still need help plz
still nothing need help
Brake_L8
Jan 20, 2015 09:44 AM
LastChance719
Dec 3, 2014 07:55 PM
ExMustangOwner
Aug 18, 2002 06:03 AM
Red97LT1
Aug 7, 2002 05:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
