amp works with 1 sub and not 2
Old Mar 27, 2009 | 10:48 PM
StylinZ's Avatar
So here's my setup:
Audiobahn a8002T
200.0 Watt - 4.0 Ohm - 2.0 channel(s)
400.0 Watt - 2.0 Ohm - 2.0 channel(s)
800.0 Watt - 4.0 Ohm - 1.0 channel(s)
2 10" JL 10w-1
4 ohm single voice coil
125watt RMS
Ported box
Now that all of that is out of the way. Here's way happens.
hook each sub to each channel and the power light will continually fade out (along with sound) After a few times of this it'll eventually cut off and then turn back on and the sub will shoot out and then th protection light will come on.
hook 1 or 2 bridged............ same thing..
hook 1 to 1 channel and it works perfectly.
Any suggestions?
TIA
Old Mar 27, 2009 | 11:52 PM
burnout96's Avatar
you may want to check your ground onto the amp. this may be a problem as well as the subs may be internally shorting out. check for clipping as well
Red Hawk 94
Mar 18, 2019 04:03 PM
Jason Short
Jan 19, 2015 06:34 PM
NewsBot
Jan 8, 2015 11:29 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
