1995 3,.4L no-start... Fuel Pressure issue??
Old Mar 21, 2009 | 08:15 PM
Dave_A's Avatar
Ok...
Car ran fine the last time I ran it (about 3 days ago)...
I was running it parked, to heat up the inside & dry it out (separate issue)...
Shut it off, and came back to start it back up this morning....
It ran like absolute crap... I thought I might be low on gas... Drove it to the gas station, stalled on the way, no restart...
Now it won't start...
If I'm lucky, pumping the accellerator while cranking *MIGHT* get me a single cylinder firing... But that's it...
Fuel pressure at the pressure-check valve is 30 PSI with the key on, engine off - but immediately drops to zero a few seconds later...
Old Mar 22, 2009 | 05:56 PM
Dave_A's Avatar
Further testing done today...
EVERY cylinder flutters between 60-90PSI for compression testing... The engine will not run on starter fluid, so I'd say that wipes out the fuel pressure question.....
I doubt this is a head gasket issue (woiuldn't that result in only one or two cyls having odd compression), or solely fuel related...
Timing chain jump?
As noted above, I idled the car (parked) for about 30min with the heat on, to try and dry it out inside...
Turned it off... Then started it back up a few days later & tried to drive to the gas station... It ran like crap (which I attributed to being low on gas) and then stalled when I hit a stop light...
No re-start...
Old Mar 23, 2009 | 02:46 AM
JooneJune's Avatar
Check for spark.
"I was running it parked, to heat up the inside & dry it out (separate issue)..." What does this intale? Could be part of the problem, what was wet that you needed to dry?
Old Mar 23, 2009 | 11:51 AM
Dave_A's Avatar
It has spark...
I can even get it to fire one cylinder - or backfire out the exhaust or intake - if I crank it while pumping the gas..
What I can't do, is get it to actually start... Even with starting fluid up the intake (Which, on my Z28, is how I diagnosed a past fuel-pump failure - the car would 'run' on spray, but not on it's own fuel system)....
When I pulled the plugs to test compression, they were ALL fuel-fouled - black, wet & smelled like gas....
I am really suspecting that the timing chain jumped - it's acting alot like a motorcycle I had that did this... Fortunately, IIRC the 3.4 is not an 'interference' valve train (ala many *** cars, where if the timing chain or belt goes, the engine eats itself)....
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Burn_Out
Aug 18, 2002 08:49 AM
