Rockford amp question
Old Jul 17, 2002 | 09:15 AM
blue89iroc's Avatar
Post Rockford amp question
Would a Rockford 300s amp be a good choice to run the standard JL sub that comes with the stealthbox or is this too much power?
75 watts RMS x 2 at 4 ohms
150 watts RMS x 2 at 2 ohms
300 watts RMS x 1 at 4 ohms in bridged mode
If there is another Rockford with the remote amp control that you think is better, please let me know!
Thanks for the replies.
Proud new owner of a 1997 Z-28 M6!!!!! Let the fun begin!
--------FOR SALE---------
1989 Blue Iroc-Z
Edelbrock Headers, High-flow cat, Fastchip, Airfoil, K&N's.
Old Jul 17, 2002 | 09:26 AM
LS1 RULZ's Avatar
300W will work fine. I was running 600W to my JL 10W3 D4 until I recently switched to a 10" Alpine Type-S 1041D.
Old Jul 17, 2002 | 12:30 PM
blue89iroc's Avatar
Thanks for the reply. Your stealthbox came with a D4? I thought they came with D2s. And how does your alpine sound? Would you recommend the Type-R or S and is 300 watts enough for these subs?
Old Jul 17, 2002 | 02:16 PM
redz_02's Avatar
Why don't you get a JL 300/1 they are pretty cheap and will match the sub for about the same price off of the net. Plus they have the R.I.P. circiutry in which you get the same power from different amounts of resistance (aka ohms).
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
-Borla (the expensive cut-out)
-Wisperlid W/K&N
-FRA
-Cags eliminator
-Strange 4.10's
-G2 Rear Girdle
-Valv. Synthetic 10W-30
-Redline gear oil
-Fat hurst shift ****
-Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtr 900.2, Kicker 12L7 in a milhouse, Focal polykev K2's.
Old Jul 17, 2002 | 03:27 PM
LS1 RULZ's Avatar
I used to have a D2 in my JL Vantage Stealthbox. When I got the MTX Thunder 6500D amplifier I wanted to run it at 2ohms so I switched to the D4. Now I've replaced that with the Type-S. I'm very happy with the performance of this sub. I recommend it highly for use in a JL style Stealthbox. I think it would make a great match with your amp.
http://images.cardomain.com/installs...32_89_full.jpg
[This message has been edited by LS1 RULZ (edited July 17, 2002).]
Old Jul 18, 2002 | 07:49 AM
maddboost's Avatar
Well first of all make sure you buy the stealthbox and not the vantage box. The stealthbox is made out of molded fiberglass and is much more riggid than the plastic vantage box, which will result in much better bass response. Second the sub that comes in a stealthbox is a 10W3-D2. You can either wire it up in parrallel and get a 1 ohm load or in series and get a 4 ohm load depending on your amp. The best amp for that sub would be a JL250/1 is a very efficient amplifier and definitly one of the best on the market. Rockford sucks stay away from it.
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
Old Jul 18, 2002 | 04:24 PM
blue89iroc's Avatar
Maddboost,
Have you used Rockford before? I was under the impression that they weren't bad, they weren't great, but they did the job. Also, I like the remote bass boost for the pure fact of being able to tune the sub while driving.
Anyone else have opinions on Rockford?
1989 Blue Iroc-Z
Old Jul 18, 2002 | 04:41 PM
LS1 RULZ's Avatar
RF amps have been work horses for years. I don't particularly like the looks of them myself but they far from "suck". Does that make sense? Anywho...On a dollar per watt bassis they're a pretty good buy. That 300W mono spec is a conservative rating too. It should make an exceelent subwoofer amp.
IMO of course.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
NewsBot
Jan 8, 2015 11:29 PM
jakeSS
Jul 22, 2002 06:54 PM
Absolute Z28
Jul 19, 2002 02:21 PM
