Program: LS1 Edit
Old Mar 14, 2009 | 06:06 AM
trans_am7935's Avatar
Program: LS1 Edit
so i was told that a '96 and '97 LT1 have an OBD II computer? if this is true then would LS1 edit work on it? if not wut can you use that is similar to it. cause i was thinking about getting it and having my uncle who works at the dealer teach me how to use it. does anybody think that LS1 edit is worth the money, like $600?
Old Mar 14, 2009 | 07:09 AM
AL SS590 M6's Avatar
LT1 edit was first and designed for your LT1 ride.
And how is this an LS1 engine question? It's a computer/tuning question and we have a forum for that.
Calling in the moving van.
Old Mar 15, 2009 | 11:12 AM
ak95ta's Avatar
LS1 edit is not worth the $600 they want for it, however HP Tuners Pro is worth the $650. EFI Live would even be better the LS1 edit. None of the programs I listed will work on the LT1 PCM (any year). Tunercats and LT1 Edit are about the only 2 for the LT1.
Old Mar 15, 2009 | 11:34 AM
glenb1991's Avatar
if your problem is getting something for your obdii i think you can just get a different cord for either lt1 edit or tunercats so you can use it for your lt1 like us obd i guys do
Old Mar 16, 2009 | 07:33 AM
Each new iteration of PCM is upgraded and needs its own editor. It's not just a cable change.
Old Mar 16, 2009 | 01:12 PM
bobdec's Avatar
Yep +1 it's the software to match the PCM that's the problem, only three types of cables for F-Body OBD1 up to 1994, OBD1.5 1995 (OBD1 with an OBD2 aldl connector) and OBD2 1996 and up... For OBD2's read up on Jet Dynamic Spectrum Tuner s/w it runs about $400.00 about the lowest around for PC based programmers.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
