What plugs for my trick flow heads
Old Feb 28, 2009 | 07:16 PM
crazycat's Avatar
I did a search but cant find the anwser. What is the best plug for my boosted 383 with trick flow heads , will be running up to 18psi ? and what seems to be the best gap ? thanks
Old Mar 3, 2009 | 05:40 PM
Boosted_Z28's Avatar
Autolite AR-3932 plugs would work fine for that application gapped at .030".
Old Mar 3, 2009 | 06:06 PM
ak95ta's Avatar
Im running autolite 104's, also gaped at 30. Work fine for me.
Old Mar 3, 2009 | 06:13 PM
crazycat's Avatar
Thanks guys ..
Old Mar 5, 2009 | 12:41 PM
mzgp5x's Avatar
Zex (power racer series) 97ss 383ci M6 D1. B.
Old Mar 5, 2009 | 06:30 PM
crazycat's Avatar
These look like they would work nice.. I will try a set after my new engine is broke in.. $50.00 a set though...
Old Mar 5, 2009 | 09:37 PM
mzgp5x's Avatar
I have used many NGK cold plugs with the single electrode. They all fowled alot. Had to have the AFR correct... always. If I lost a boost intake tube, instant fowling. The ZEX plugs do not fowl nearly as easy. Glad I made the switch. 15psi boost. B.
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
