95 3.4L, OBD '1.5' - Can't get scan tool to connect
Old Feb 25, 2009 | 09:03 PM
Dave_A's Avatar
95 with a 3.4 V6.
OBD II Connector, I assume this is an 'OBD 1.5' vehicle'???
Borrowed a CanOBD 1 & 2 (innova) scanner from Shucks, and it fails to connect...
What scanners work?
I would preferr not to mess with 'paper-cliping' codes....
Old Feb 25, 2009 | 09:28 PM
shoebox's Avatar
Wow, I did not realize that the 3.4 had the same DLC as the LT1. You just need the correct adapter cable for an OBD-I scanner or adapt a 12 pin cable like this. You couldn't flash codes with a paper clip, anyway.
Rod Bender
Nov 7, 2023 02:30 PM
Victor Lamb
Aug 26, 2017 02:52 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Timberwolf
Aug 18, 2002 07:39 PM
LT1
Jul 2, 2002 08:27 PM
