'96 Subframe Concern?
Old Feb 24, 2009 | 11:10 AM
KajunKadillac's Avatar
Not to long ago, i took a good look underneath my car, and noticed that the front subframes, right next to the jack points, on both sides, seem to be dented upwards, and stretched. I know the car got into a wreck before i purchased it. But dont know the true exent of the damage (almost all front end components were replaced. except the window washer resevoir)
I will take pics when i get the opportunity, probably late afternoon. But before i do that, any thoughts, i suspect it may be bent, but dont know how serious it is, all four wheels make contact, had a front alignment recently, and shop didnt mention anything. Steering wheel is off set though, and nonresponsive (but i think thats the rag joint, which i will soon replace with an eliminator). And if they are bent, should it be a big concern?
Old Feb 25, 2009 | 07:36 PM
Got a few pics: Heres the drivers side frame rail:
Any thoughts?
Old Feb 26, 2009 | 07:50 AM
RUDEDOG's Avatar
Maybe wrecker driver used t-hooks and put to much tension on the cables. Or the more likely scenario the body shop used these holes as attach points to straighten the frame. They should have centered your steering wheel when they did the alignment. I would take it back and let them do it on the machine.
Old Feb 26, 2009 | 10:26 AM
Ok, ill take it to the alignment shop again soon, but it seems that the sheet metal on the right of the rail is broekn off, will that need to be fixed? Just trying to see if it is a serious stuctural issue as well, cause to help stiffen it i plan on welding on some subframe connectors.
Old Feb 27, 2009 | 07:01 AM
RUDEDOG's Avatar
Sfc,s are always a good idea on these cars.
Old Feb 27, 2009 | 11:41 PM
mrmint69's Avatar
Our body shop has equipment that measures certain point on the car and they have to straighten them to factory specs. It a real shop did the work they would have it back to original and the car would have the wheels aligned. I put sub frame connectors on mine and the bolt holes all lined up. Mine had been in a front end accident but it was at low speeds.
Mar 13, 2016 03:37 PM
pepon214tx
Sep 20, 2015 04:48 PM
marlar98
Sep 19, 2015 07:53 AM
Henson071
Sep 18, 2015 04:01 PM
cmsmith
Sep 14, 2015 09:25 PM
