rear suspension noise
Old Feb 14, 2009 | 01:59 AM
grimjeeper73's Avatar
i have a 95 z 28 i have a creaking/rubbing noise in the back that sometimes will go away for a day or 2 but then it will come back any ideas on what this annoying noise is
Old Feb 14, 2009 | 08:19 AM
n2ceptor's Avatar
Control arm bushings??? Panrod bushings??? Sway bar end links??? Shock??? Rubber donut on top of spring????
Are the bushings stock or aftermarket??? Poly bushings will make noise...
Old Feb 14, 2009 | 01:30 PM
its all stock it sat in a garage for three years it only has 63000 miles on it maybe i have some dry rotted bushings?
Old Feb 14, 2009 | 02:27 PM
n2ceptor's Avatar
You might try spraying a white lithum grease like Permatex #81981 in and around the bushings...... Could help.. Wont hurt... DO NOT use anything like WD40, a penetrating oil.... This will degrade the rubber...
Old Feb 16, 2009 | 02:59 PM
steelerfan's Avatar
I had the same thing,turned out to be the LCA bushings,spraying them didn't help mine,rather then just replace them bushings which can be a lot of work I replaced the LCA's with units that had poly bushings with gease fittings,that took care of the problem
Old Feb 16, 2009 | 11:32 PM
sometimes i also get a dragging metal on metal noise but i just put new brake pads all the way around so now im tryin 2 figure out if its one or 2 problems
Old Feb 17, 2009 | 02:43 PM
n2ceptor's Avatar
There are grease points on the calipers.. Did you grease ????? Alot of people forget about this and it could cause the pad to stick...
Old Feb 18, 2009 | 07:49 PM
thanks
im gonna try that i bet 100 dollars thats what it is because i didnt even see that thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
94z28jbw
Sep 8, 2002 03:22 PM
guionM
18
Jul 23, 2002 04:24 AM
