Lt1 ABS delete line size?
Old Feb 19, 2009 | 04:57 PM
Ta4life's Avatar
i have 4 chan i guess since i have 4 brake lines and 2 from master after module was taken out.
what size brake lines are these so i can get my T's and fittings
Old Feb 19, 2009 | 07:44 PM
camarobird92's Avatar
They are metric lines and fittings. Good luck finding metric stuff. I cut the stock fittings off and put on new standard flare fittings. I forgot the exact size though. I think 1/4" for the small lines and 3/8" for the large line. Mine is a 3 channel though. You might only have the small size lines. There is a pretty good write up here about it. Search around a little and you should be able to find it.
Old Feb 19, 2009 | 07:56 PM
Ta4life's Avatar
i planed on cutting flares off to neaten it all up
so cut pieces off and prob just take it to store to figure out what sizes ima need and get T's that fit
Old Feb 19, 2009 | 07:57 PM
jakesz28's Avatar
Here is a little something I wrote up. http://www.jakesz28.com/ABSdelete.html
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
crazypurgatory
Jan 12, 2015 10:45 PM
ddr698
Jan 9, 2015 10:05 AM
