whos running solid mounts?
Old Feb 11, 2009 | 12:43 PM
reamo04's Avatar
just wondering what kind of mounts you are all running if your running solids.
Im looking at a set of morosos
Old Feb 11, 2009 | 08:23 PM
94LT1_89TTA's Avatar
I have run them in the past on high horsepower carb applications. They work fine.
I would be apprehensive about running them with a knock sensor. They could work fine, but they might also cause some false knock.
The urethane ones are the best of both worlds. Strong but with some damping ability too.
Old Feb 11, 2009 | 09:44 PM
ford's Avatar
Tis what I use.
Old Feb 11, 2009 | 09:55 PM
reamo04's Avatar
Originally Posted by ford
Tis what I use.
you also dont have a 60# turbo to try to find a place to securely mount
Old Feb 11, 2009 | 10:01 PM
ford's Avatar
Psh... that baby TV75.....
Wonder how much my T76 weighs...
Old Feb 11, 2009 | 10:17 PM
ak95ta's Avatar
I am going with solid ones, I noticed that my poly ones started to melt.
Old Feb 11, 2009 | 10:21 PM
reamo04's Avatar
idk, my t70 was only 18...haha
Old Feb 11, 2009 | 10:36 PM
ford's Avatar
Pretty sure mine weighs in more than that.
Old Feb 11, 2009 | 11:26 PM
reamo04's Avatar
i think 76's are around 25ish or so
Old Feb 19, 2009 | 07:16 PM
CALL911's Avatar
I personally would reccomend poly over the solid mounts.
Old Feb 19, 2009 | 07:45 PM
reamo04's Avatar
actually guys, i am going with motor plates instead of either so, i'll let you all know how I like them haha
Old Feb 19, 2009 | 08:05 PM
jay_rich's Avatar
lol change ur mind alot eh...I am kinda wishing i did solid for the same reason of you. I dont wanna run flex pipes But i cant mount it anywhere on the motor.
Jay
Old Feb 19, 2009 | 08:12 PM
reamo04's Avatar
Jay
well, motor plates will tie it into the chassis more, so....just feel alittle bit better about them. Im going to have to see if I can build a set around my turbo kit though, otherwise, it'll be solid mounts it is. I dont really plan, i just go with the flow.
Lederman1976
Nov 30, 2014 05:21 AM
Omega9
Aug 2, 2002 12:33 AM
Absolute Z28
Jul 19, 2002 02:21 PM
guionM
18
Jul 11, 2002 01:45 AM
