Is your car supposed to do this?
Old Feb 1, 2009 | 07:48 PM
Jachin99's Avatar
When i first start my car up, it will idle at 1000 rpms for about 20-40 seconds then settle down to between 6-800 rpms. Is it supposed to surge like that when you first start it?
Old Feb 2, 2009 | 12:55 AM
$hawn's Avatar
It will do that a little when it's colder out.
Old Feb 3, 2009 | 11:44 AM
ibanez6rg's Avatar
Sounds normal. Cars will do that on cold startups.
Old Feb 5, 2009 | 05:23 AM
The PCM is programmed to increase the idle speed on cold starts, with a table of RPM vs coolant temp. There should not be a "surge" in the idle speed, just elevated, and slowly come down as the coolant heats up.
Not exactly an "Exhaust" topic
Old Feb 11, 2009 | 11:46 PM
6SpdLT1Z's Avatar
All cars do this. I love starting my dads 5.3L when it's cold out. It sounds awesome when it starts up and jumps up to ~1200-1300rpm.
Old Feb 19, 2009 | 07:49 PM
monkey_fuerte's Avatar
That's good to hear. I always thought there was something wrong with my car because it did that.
But on that note, when I'm driving and the engine is already heated up, if I put it in neutral at any speed more than 5 mph, it will idle at about 900 rpms instead of the normal 800 at a stop. Is this something of any concern?
Old Feb 26, 2009 | 01:51 AM
Fatdog2's Avatar
Sounds like a vacuum leak somewhere.I'd take the car in and get it checked out.A little hose can cause this I think.my02.
Old Feb 28, 2009 | 09:41 AM
bobdec's Avatar
This is also normal. It's called 'Throttle Fowler Offset' in the PCM. Purpose is to prevent stalling/stumbling when coming to a stop with no throttle. It varies from +0 to +400 RPM, dependent on speed, the faster you go the higher the TPS%=0 (no throttle) RPM will be.
Old Mar 7, 2009 | 01:43 PM
^that's good to hear.
But I think I'll take fatdog's advice and have someone take a look when i get a chance. can never be too picky with cars.
Old Mar 7, 2009 | 08:14 PM
"follower"
Old Mar 8, 2009 | 10:17 PM
shoebox's Avatar
IDK, Fowler sounds kinda neat.
Old Mar 16, 2009 | 06:12 AM
grimjeeper73's Avatar
my car idles at 2000 till it gets warmed up i dont even have to give it a little rev to get going lol
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
USAirman93
Nov 24, 2014 03:37 PM
