Emissions Failure - NOx
Old Dec 22, 2008 | 06:30 PM
PLANT PROTECTION's Avatar
I just picked up a 1994 Firebird with a 3.4l. The car had a DTC 76 which is EGR when I bought it. I replaced the EGR with a junkyard unit, the code went away so I proceeded to take it for an emissions check. It failed the first time in HC 2.50 with a .80 limit and NOx with 3.50 with a 2.50 limit, CO passed with 9.00, 15.00 limit. Long story short, cat was gutted, replaced it with a Walker unit, HC passed with .73, same .80 limit and CO registered 0.00. NOx failed even worse the second attempt, 4.50 with the 2.50 limit. Where should I go from here? The plugs looked a good tan and the car seems to run good. Other than that, no other parts were checked or changed. Thanks for any input.
Old Dec 22, 2008 | 07:05 PM
transamtom's Avatar
Nox is created from the combustion chamber being too hot,it is either running lean or the used EGR valve is malfunctioning.
Old Dec 30, 2008 | 12:15 AM
ImportKILLER's Avatar
When was the last time your o2s were replaced?
Old Dec 30, 2008 | 11:11 AM
I'm sure the o2s are original @ 136k. I ended up putting a new EGR valve on and that did the trick, dropped the reading down to 2.5ish. The HC and NOx are still on the high side for a stock 3.4l imo, but this will have to do. Thanks for the input.
sleeperZ96BT
Sep 9, 2015 08:28 AM
canuck94z28
Aug 19, 2015 05:50 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RUNMYTA
Jul 15, 2015 07:50 PM
Camaro ChriSS
Sep 4, 2002 05:31 PM
