PLANT PROTECTION |
12-22-2008 06:30 PM |
Emissions Failure - NOx
I just picked up a 1994 Firebird with a 3.4l. The car had a DTC 76 which is EGR when I bought it. I replaced the EGR with a junkyard unit, the code went away so I proceeded to take it for an emissions check. It failed the first time in HC 2.50 with a .80 limit and NOx with 3.50 with a 2.50 limit, CO passed with 9.00, 15.00 limit. Long story short, cat was gutted, replaced it with a Walker unit, HC passed with .73, same .80 limit and CO registered 0.00. NOx failed even worse the second attempt, 4.50 with the 2.50 limit. Where should I go from here? The plugs looked a good tan and the car seems to run good. Other than that, no other parts were checked or changed. Thanks for any input.
