getting rid of the ignition switch
Old Dec 14, 2008 | 03:06 PM
tom3's Avatar
I've brought this up in the past: I had several ignition switches that burnt and now, the new one was defective straight out of the box! it's like a curse
I don't understand why something that should be electrical has to be implemented in a ridiculous mechanical way: if you follow the path from the key to the actual switch wires, it's a stupid design and a couple relays and switches would make it simpler.
So, I'm trying to figure out what is the max intensity I should expect to go through the relay for 1) when the power is on and 2) during cranking.
Also, if anyone has done this, where did you mount the switches? I can't think of a convenient spot that is clean, and out of the way.
Old Dec 14, 2008 | 06:57 PM
scooters97ss's Avatar
I would like to know how many they have made and how many have failed. It seems like the best way to accomplish what they set out to do in my opinion instead of having multiple keys and switches and to use less wiriing and electronics.
Knightscrapper
Feb 4, 2016 10:25 AM
blac94Z
Jun 11, 2015 06:17 PM
chevyalltheway
May 24, 2015 04:26 PM
beltrunner
May 17, 2015 10:18 PM
robcarnut
Mar 20, 2015 03:40 PM
