Torq Thrust Backspacing 17x8 Or 17x9.5
Old Jan 5, 2003 | 08:23 AM
redhotcamarogirl's Avatar
DOES ANYONE KNOW IF A 17X8 WITH BACKSPACING OF 4.75 OR 4 WOULD FIT A 4TH GENERATION CAMARO? I SEE THAT THE 17X9.5'S HAVE A BS OF 7.....THANKS FOR ANYONE'S HELP
Old Jan 5, 2003 | 04:26 PM
The stock 8" wide wheels are 55mm offset, which corresponds to a 6.65" backspace. If you bought an 8" wide wheel with a 4" backspace, the wheel would be moved more than 2.6" toward the outside of the car, moving it quite a way outside the fender line.
IMHO you do NOT want to simply go from a 16x8" wheel to a 17x8" wheel, when you get the added benefits of a wider tire footprint and a more aggressive look when you opt for the more popular 17x9.5" wheels.
Old Jan 5, 2003 | 07:40 PM
Elvis '97 Trans Am's Avatar
So you're saying that if you buy an 8" wide wheel it wheel stick way out of the fender well and of course looking retarded. I am thinking about 17 X 8's or 17 X 9.5's but do not know. The 17 X 9.5 won't rub will they?
Old Jan 5, 2003 | 07:44 PM
AW/whiteZ-28's Avatar
9.5 shouldn't rub at all
Old Jan 6, 2003 | 12:10 PM
Not exactly.... I am saying that you need the correct offset/backspace on any width wheel, or it isn't going to be located correctly within the fender line. A 4" BS on an 8" wheel will not work. A 5.5"BS to a 6.75"BS will work on an 8" wheel.
I have run OZ MonteCarlo 17x9.5 (7-1/8"BS) and AFS/ZR1 replica 17x9.5 (7.3/8"1BS) with 275/40-17's with no problems. Remember, the factory 17x9 wheels for the WS6 and SS have a 7-1/8"BS with stock 275/40's..... so the wheel wells are made for that size tire.
G-BODYT56
Jan 14, 2022 11:14 PM
TheGreenZ28
Oct 4, 2020 11:29 AM
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
realistyc
Jul 28, 2015 07:32 PM
