Nitrous vs Boost on a Bolton Lt1
Old Oct 19, 2008 | 07:11 PM
a4z28's Avatar
What would yield better times. My car has Long tubes, 373 , 3000 stall built trans, cold air, drag radials, full exhaust + some other little things. I am either looking at a p600b or s trim, Or a 100-125 shot. This is all on the stock motor.
Old Oct 20, 2008 | 09:18 AM
slomarao's Avatar
n2o wont blow the thing up so id go that route. A 100 shot should be good for 10-12 mph and a second off your ET.
Old Oct 20, 2008 | 02:09 PM
rskrause's Avatar
For a modest power boost, nitrous is going give a lot more bang for buck and for the hp. Look at the torque curve of a nitrous motor vs. a blower car and it's pretty obvious why. OTOH, to spice up a car for high performance street driving, blower (or turbo) is the way to go.
Riich
Old Oct 22, 2008 | 01:24 AM
LSWHO's Avatar
If you are doing one of those with the motor as is, then nitrous will be WAY faster. If you are going to build the bottom end a turbo or SC will be better in the long run.
Also nitrous sucks on the street... IMO.
Old Nov 2, 2008 | 08:02 AM
funina91ss's Avatar
Unless you plan on rebuilding your shot block very soon, I would go with nitrous. If you don't mind and can afford a short block rebuild soon than I would go Blower.
Dec 1, 2016 05:37 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
