Rearend?
Old Oct 12, 2008 | 03:11 PM
krillformula's Avatar
Rearend?
I havent followed the development that much of the new camaro, but what kind of rear will be in it?
Old Oct 12, 2008 | 03:36 PM
JasonD's Avatar
Admin Emeritus
4.5 link independant
https://www.camaroz28.com/gallery/ma...?g2_itemId=936
Old Oct 12, 2008 | 04:44 PM
MetalDragon's Avatar
Have we heard anything on gearing?
Old Oct 13, 2008 | 01:44 AM
Jason Dove's Avatar
3.27 for everything but the manual SS which will be 3.45 in the rear end. If you go to chevy.com/camaro there's a specifications PDF if you want to see each of the ratios for the transmissions.
Old Oct 13, 2008 | 08:58 AM
Ok thanks!
Old Oct 20, 2008 | 10:21 PM
10Redrocket's Avatar
Axle ratio
I ordered an SS today with an auto trans and the paperwork lists the axle ratio as 3.45, so I'm assuming that all the SS's have the same ratio.
Old Oct 20, 2008 | 11:46 PM
I haven't seen anything to indicate different.
Old Oct 24, 2008 | 07:20 PM
Jason Dove's Avatar
http://www.chevrolet.com/camaro/pdf/...ifications.pdf
The spec says on page 3:
Hydramatic 6L80E speed automatic(SS) w/Tapshift
Final Drive Ratio: 3.27
Old Oct 28, 2008 | 12:33 PM
mdenz3's Avatar
Does anyone know the ring gear diameter on these?
Old Oct 28, 2008 | 09:18 PM
Correct!
My fault, I was looking at standard equipment on my paperwork. In the options section under the auto trans it lists the ratio as 3:27.
Sorry guys.
Old Nov 16, 2008 | 02:55 PM
the wrenchman's Avatar
Question: Who will be supplying the axle? ZF, Saginaw, Dana. Any schematics?
Old May 21, 2009 | 04:15 PM
prophet33's Avatar
hmmm kind of a low gearing what do u guys think bout 4.10 gears
Old May 30, 2009 | 09:21 AM
jay_lt4's Avatar
Originally Posted by mdenz3
does anyone know the ring gear diameter on these?
8.8"
Old Jun 8, 2009 | 09:18 PM
HeavyChevSS's Avatar
Question
Does anyone make different ratios for this rear end. From what I remember reading the 3.45 and tall tires provide for 54mph in first gear, I would guess that a change in gear ratio would give a dramatic increase 0-60 and 1/4 ets.
Old Jun 8, 2009 | 09:45 PM
jay_lt4's Avatar
no aftermarket gears are made for this diff yet
