Rearend?
I havent followed the development that much of the new camaro, but what kind of rear will be in it?
Have we heard anything on gearing?
3.27 for everything but the manual SS which will be 3.45 in the rear end. If you go to chevy.com/camaro there's a specifications PDF if you want to see each of the ratios for the transmissions.
Ok thanks!
Axle ratio
I ordered an SS today with an auto trans and the paperwork lists the axle ratio as 3.45, so I'm assuming that all the SS's have the same ratio.
I haven't seen anything to indicate different.
http://www.chevrolet.com/camaro/pdf/...ifications.pdf
The spec says on page 3: Hydramatic 6L80E speed automatic(SS) w/Tapshift .... Final Drive Ratio: 3.27 |
Does anyone know the ring gear diameter on these?
Originally Posted by Jason Dove
(Post 5651368)
The spec says on page 3: Hydramatic 6L80E speed automatic(SS) w/Tapshift .... Final Drive Ratio: 3.27 My fault, I was looking at standard equipment on my paperwork. In the options section under the auto trans it lists the ratio as 3:27. Sorry guys. |
Question: Who will be supplying the axle? ZF, Saginaw, Dana. Any schematics?
hmmm kind of a low gearing what do u guys think bout 4.10 gears
Originally Posted by mdenz3
(Post 5656652)
does anyone know the ring gear diameter on these?
8.8" |
Does anyone make different ratios for this rear end. From what I remember reading the 3.45 and tall tires provide for 54mph in first gear, I would guess that a change in gear ratio would give a dramatic increase 0-60 and 1/4 ets.
no aftermarket gears are made for this diff yet
