Hows this fuel press on new charger???
Old Aug 12, 2008 | 10:21 PM
bski224's Avatar
Reads 40psi @ idle 51 @ WOT Is that safe enough, 8psi pulley, 42lb inj. Only seen about 6psi of boost according to gauge.
Old Aug 12, 2008 | 10:54 PM
roguedriver's Avatar
Seems like its working. I'm assuming you have a boost referenced fuel regulator? Hard to know for sure. You really need a wideband reading to know for sure. You can take a plug reading, but thats kind of a pain cause you need to make a WOT run and shut off immediatly then pull some plugs and take a look. If you have a way to scan it (datamaster or freescan) then you can get a half *** idea by looking at the O2 readings. I've found in my experience that readings in the .950mv range usually show around 11.5:1 on my wideband.
Ken R.
Old Aug 13, 2008 | 08:40 AM
bski224's Avatar
Hello, I have stock pump with the supplied procharger fuel booster. Im thinking about wideband but is it really necessary with the fuel gauge?? Some say yes some say no.
Old Aug 13, 2008 | 08:51 AM
RealQuick's Avatar
fuel gauge and WB have nothing to do with each other. The fuel gauge is telling you how much fuel pressure is in the rail.
Your A/F is determined by how fuel pressure is at the back of the injector and how long the injector sprays for. You can control your A/F by playing with the time the injector stays open. By varying this time, you change your A/F ratio... so the fuel pressure gauge isnt going to help you dial in your A/F. It will tell you if you are having a fuel delivery issue though.
Lions3
Aug 30, 2002 01:03 PM
CamaroZBoy
Aug 19, 2002 12:41 PM
CLEAR
Aug 16, 2002 02:35 AM
LumpyCamZ28
Aug 13, 2002 09:16 AM
CeeBee94Z
Jul 31, 2002 02:20 PM
