Torque Converter
Old Jul 29, 2008 | 03:12 AM
twcblackhand6970's Avatar
So, my mechanic suggested I put in a 2025 Stall TC, which I'm okay with because I'm trying to keep the tranny temp fluid down. Another quick thing, my car is going to be my DD and I may (one day) goto the track to get a 1/4 time, but it isn't going to be close to a "track car". I was just curious what the stock stall was on a 1994 z28?
Old Jul 29, 2008 | 03:15 AM
'94 Bad A Z28's Avatar
Umm... like 1800 or 2000, it'll brake torque to about 1650 or so.
Old Jul 29, 2008 | 03:29 AM
Brake torque, what's that? When it actually starts going?
Old Jul 29, 2008 | 08:03 AM
93transam1234's Avatar
When you hold the brake down and press the gas, the tires will start spinning at around 1800-2000 rpm's. I dont know what other mods you have or going to have done. But a good Vigalante or Yank TQ with a stall of about 3200 and a tranny cooler and you should be fine. Just make sure you get one with a lock up
Old Jul 29, 2008 | 01:47 PM
How high you can bring the rpm's by holding the brake and pressing the gas peddle without the tires spinning.
Old Jul 29, 2008 | 04:06 PM
What the best stall for a bolt on LT1? I thought at the RPM when the torque curve began to level off is what stall you were supposed to get. So for a stock LT1 would put that at about 2400RPMs?
Old Jul 30, 2008 | 12:56 AM
I went out to my mechanic today to see the progress and he's still no done, but I did see the type of TC the speedshop gave him. Its a B&M Tork Master Stall 2000 RPM. Is this TC okay for street use on a bolt on LT1
Old Jul 30, 2008 | 01:13 AM
That converter is too small for your car, it's barely any higher of a stall than your stock converter.
Old Jul 30, 2008 | 01:26 AM
hmmm, maybe I can talk to him then, about a little bigger
what would be good? 2400 - 2800?
But overall, this TC won't crap out on me, like not a "bad" TC? Just has a low stall, that's it?
Old Jul 30, 2008 | 04:46 AM
rskrause's Avatar
Best track performance for an NA car is seen with a stall speed somewhere near peak torque. Maybe a bit higher. Most people would find this intolerable on the street though and it would generate a huge amount of heat. My own preference would be a lower rear gear and a tight converter.
Rich
Old Jul 30, 2008 | 04:48 AM
My 3600 is great on the street.
Old Jul 31, 2008 | 03:07 AM
But will the B&M do okay for daily driving conditions? Like not break? or poop out on me?
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
