LT4 Cam Question
Old Dec 27, 2002 | 12:51 AM
globalco's Avatar
LT4 Cam Question
Apparently there are two LT4 cams. There is the LT4 HOT Cam, 218 / 228 Duration@ 0.050, Hydraulic Roller Camshaft and the Chevy LT4, 203/210 Duration @ 0.050, Hydraulic Roller Camshaft. From the SDPC information the not Hot cam is a better street cam. Does anyone have any real world experience with either of both of these.
I am building a smog street motor using modified Vortec heads, SLP runners and manifold.
Thanks
Jim
Old Dec 30, 2002 | 11:55 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Where in California are you? I have the LT4 HOT cam, and let me tell you its not a mild cam. It requires a custom chip and valvetrain mods to be sure the heads can handle the lift. The other LT4 cam came stock in the 96 LT4 Corvette engine. Its a nice mild cam for a daily driver you want a little more power out of, but not for racing. And it doesnt require a custom chip. I think the best cam for the Vortec heads would be the ZZ4. It has a nice long exhaust duration, where the Vortec heads need the help. But again with its high lift the heads have to be setup for it.
Old Jan 2, 2003 | 11:04 AM
S. Holley's Avatar
What are the lift numbers on the Hot LT4???
Old Jan 4, 2003 | 07:53 PM
PLANT PROTECTION's Avatar
.492 I/E with 1.5 rockers and .525 I/E with 1.6.
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
May 25, 2015 09:35 PM
95chwagon
Jan 13, 2015 09:19 PM
