engine removal
Old Jul 25, 2008 | 09:26 PM
Chevycobb's Avatar
engine removal
will the preferred method of removal still be out the bottom like the 4th gens?
is it bad that I am tempted to start piecing together an lsx without knowing if I can get this car?
Old Jul 25, 2008 | 11:37 PM
Jason Dove's Avatar
Based on this image, I think it'll easily come out the top.
BTW: My 4th gen motor easily came out the top, not sure why you're suggesting the 'best' way was to drop it.
Old Jul 26, 2008 | 06:09 AM
Chevycobb's Avatar
because thats what chevrolet suggested IIRC.
...and from personal experience
Old Jul 29, 2008 | 03:14 PM
Whitten's Avatar
And because I have seen the guys at GMMG go from car on the ground in running trim to having the entire trans,motor, and K member out in less than 20 minutes...
Seriously they used to race each other in the shop. I can't be sure but I think Mike told me they were able to get one out in 12 minutes start to finish one time but that was with two guys working on it.
Old Aug 14, 2008 | 06:09 AM
DAKMOR's Avatar
Doesn't it look like you could put t-tops on that vehicle?
Old Aug 14, 2008 | 08:17 AM
JeremyNYR's Avatar
Not really. It does look like non-removable glass panels can be put in, which would be pretty cool. As far as actual t-tops, I wouldn't be cutting out the roof supports just above the windows without a roll bar with welded in door bars. They look pretty damn structural to me.
Old Dec 15, 2008 | 05:10 AM
SCNGENNFTHGEN's Avatar
Looks like a fine work of art to me. I wouldn't want to cut it up for T-tops either. Glass tops wouldn't be a bad sacrifice IMO. It does look like the engine should come right out the top.
Old Feb 9, 2009 | 01:48 PM
2010_5thgen's Avatar
It's spelled C-A-M-A-R-O!!!!!!
Old Feb 9, 2009 | 02:23 PM
Chevycobb's Avatar
explain what you mean by "checking out" the cAmaro? you just saw it at a car show or something? just how many 2010 camaros have you worked on?
Old Feb 9, 2009 | 02:30 PM
from what ive seen in the gmpp videos of the sema cars, theres not too much involved in removing the engine from the bottom.
Old Feb 9, 2009 | 04:07 PM
Chevycobb's Avatar
looks very similar to the way a 4th gen's is removed, and that can be done in a day by a lot of people with just basic tools.
Old Feb 10, 2009 | 07:07 AM
how high would the body have to be lifter to get the front suspension and motor to come out? you have to have some pretty serious jack's and stands to do this at home.
Old Feb 10, 2009 | 09:40 AM
Chevycobb's Avatar
what most people do, myself included, is to use either stacked 2x4's or concrete blocks with the jack stands on top of those to hold the car up. getting the front of the car up is done with the cherry picker/engine hoist with some chains or strong straps.
I got a bunch of pics of the process of when I did it at home. it was messy, but I have done it by myself in a day.
Old Feb 10, 2009 | 09:53 AM
too much work for me. id rather pay someone to pull the motor out for me. im not very mechanically inclined when it comes to huge projects like that. plus i have a disorder where i cant start a project and leave it unfinished. i would have to spend the entire time working on it without any sleep. i cant stand having unfinished projects.
Old Feb 10, 2009 | 10:12 AM
super83Z's Avatar
Originally Posted by SP DEMOSTHENIS
DATE: 02-09-09
Comaro Engine
I just checked out the new Comaro. Here's what I've noticed. Almost
every forum out there there's must be so many young dudes that's never
taken apart and engine and then there's some that have.
Why would General Motors make the new motor so complicated??? It's incased
in aluminum and stainless steel??? They've made it tiresome to work on?
Why would they do this? It's not a Ferrari...
It's a New Comaro that will compete with the 05-11 Mustangs.
Granted the 2005-2011 Mustangs are easy to work on, why not make the Comaro the same way???
I believe if General Motors doesn't get a handle on the accessability of the mechanical components they will eventually run off buyers down the road.
Ford made there Mustangs easy as cake to upgrade and replace mileage parts...
Watch and learn boys. Look at the screws encasing the engine in the photos.
It's
This isn't Star Trek. It's the good ol' "U. S. of A."
Peace out Comaro lovers and good luck.
We are all dumber for having read this.
