help should I be scared
Old Jul 15, 2008 | 09:38 AM
da9mili's Avatar
ok well I don't know if it's an exhaust problem but when I start my car up it starts up fine but then I rev it to about 3000 rpm there's a pop after. It only does it whenever I first start it up. I don't have any mods except k&n n flowmasters. It's a 2000 z28 with 67000 miles on it. Again it revs fine but when I release it gurgles then pops. Thanks guys. Love this websight oh and it's an automatic
Old Jul 15, 2008 | 12:59 PM
ACE1252's Avatar
Does it do it when the engine gets warm? My LT1 does the same thing until it gets warm.
From what I've read on here, the popping is just a thing where the engine is cold and in open loop mode. The car is not burning all the fuel in the cylinders and then it gets shoved into the exhaust pipe were it ignites and you hear the pop.
Once warmed up, the car goes into closed loop where it meters the fuel more precisely and hence, burns all the fuel in the cylinder.
Old Jul 15, 2008 | 06:40 PM
bowtiekid's Avatar
Its just becuase your revving it and the popping you are hearing would be backpressure
Old Jul 15, 2008 | 08:23 PM
da9mili's Avatar
Yea it only does it when I first start it up after it's been sitting for a couple hours. Also it only does it if I rev it about 5 secs after I start it up then after that it's normal. Thanks guys
Old Jul 16, 2008 | 09:35 AM
z95lt1's Avatar
not a good ideal to rev the car up to 3k on a cold start anyways always let the motor warm for a few mins. then dog on it. read above post and that is more then likely what is going on.
Old Jul 16, 2008 | 09:39 AM
glenb1991's Avatar
i believe the term for it is a backfire... and yea... revving your engine when you just start it up isnt a good idea. your oil hasnt had a chance to fully go through your engine, and could result it many more problems that im sure you wouldnt wann ahave to deal with. jus my .02
Old Jul 16, 2008 | 11:52 AM
irocbsa's Avatar
Free revving is never a good thing for the engine, cold or hot.
Old Jul 17, 2008 | 03:05 PM
da9mili's Avatar
Thanks again. yea it doesn't do it when it's warm but just to be safe I'm no longer gonna free rev. Just to make sure my ride stays running good.
Old Jul 17, 2008 | 05:25 PM
slomarao's Avatar
un burned fuel burning in the exhaust. Dont free rev the engine, only under its under load.
My car does it every once in a while.
Matt W
Apr 24, 2015 12:54 AM
ModdedNerd
Dec 25, 2014 05:51 PM
StealthElephant
3rd Gen / L98 Engine Tech
9
Mar 2, 2003 03:44 PM
K!D
West South Central
31
Oct 24, 2002 05:12 PM
ROGERARRAMBIDE
Sep 10, 2002 04:40 PM
