backfiring and tach bouncing help!
Old Dec 25, 2002 | 05:01 PM
StealthElephant's Avatar
Idles like a dream, at WOT pulls perfect. Try and drive it on a normal road and the tach bounces all the way to 5k, the car jerks you can hear somethings wrong in the engine.
Replaced spark plugs, ignition module, distributor, no help.....whats wrong? MAF? O2 sensor?
Old Dec 25, 2002 | 09:02 PM
grumpygreaseape's Avatar
miles on car? 87 is the big cap still? is the ground lead in the cap under the coil still there? if its a small cap take a squirt bottle of water and give the remote coil a bit of a wet down, see what it does. new distributor means? a complete new distributor from gm, a cheesy pep boys reman, a new body and transferred parts, are you using a NEW, as in out of an ac delco cardboard box that you opened, ignition pickup? delco ignition module? info please
Old Dec 30, 2002 | 07:18 PM
1981zzz's Avatar
you sound like you might be a hair out on your timing or your throttle posision sensor if u have tpi
Old Dec 30, 2002 | 11:42 PM
vacuum leak in the intake plenum well it's fixed...
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
LazyLemming
Aug 29, 2015 07:36 PM
techstar
Aug 6, 2015 11:20 AM
