Wrapped PS LT's
Old Jun 28, 2008 | 01:14 AM
MadMike 97 Z28's Avatar
Wrapped PS LT's
these are my race style pacesetters this was my first wrap job so the first header was a learning process but i figured out some of the tricks on the driver side that helped how the passenger side turned out.
Old Jul 4, 2008 | 01:14 AM
reamo04's Avatar
if you get it wet before you install them, the wrap will contour to the pipes better.
FYI, it'll smoke like hell the first 10-15 miles you drive it.
Old Jul 5, 2008 | 10:43 AM
silver97Z's Avatar
I've always been told header wrap is a bad idea...trapping moisture, causing rust, etc...
Old Jul 5, 2008 | 08:16 PM
Doesn't "trap moisture"..... that's not why it rusts. The mild steel get so hot from the header wrap keeping it at extremly high tube metal temperatures that mild steel is not intended to operate at, that the iron in the steel starts to combine with oxygen (= rust). Also tends to accelerate cracking of the welds from the extreme heat cycling. Racers wrap headers for improved scavenging of the hotter exhaust gasses. But race teams recognize that the headers may not last very long under those conditions. Going to be interesting to see how long these last.
Old Jul 13, 2008 | 07:25 PM
dalynchmob's Avatar
Wraped my last set, they lasted about 8 months before a 1.5" rust hole blew through. I won't be doing it again. My .02
n2oblkz
Oct 22, 2015 02:31 PM
TGGodfrey
Aug 18, 2015 06:08 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Aug 5, 2015 08:35 AM
NewsBot
May 19, 2015 09:30 AM
