braking noises
Old Dec 23, 2002 | 04:33 PM
black splitter's Avatar
braking noises
When I'm driving at a normal speed or backing out and come to stop my front end starts to make a crunching noise. When I let up off the brakes the crunching stops. Does anyone have the same problem? Or does anyone know what it is and how I can fix it? I'd appreciate any suggestions. Thanks!
Old Dec 23, 2002 | 04:57 PM
irocz383's Avatar
Did you replace the pads recently? Could be just pad meterial.
Do you get any clunking sounds over pumps on the road. If so, The caliper may be loose.
There really is a lot of things that could be wrong. I'd say your best bet is to take your brakes apart and put back together to make sure everything is were it's supposed to be.
If the noise doesn't go away move onto the suspension. Mounts, bushings, struts etc.
Happy hunting and Good luck!
The good thing is theses cars are easy to work on!!
BTW... Welcome !!
May 1, 2015 01:14 PM
Fatdog2
Feb 12, 2015 12:24 PM
Collector Car
Jan 5, 2015 10:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
squarehead
Nov 21, 2014 08:02 PM
