wheel spacers
Old Dec 22, 2002 | 01:23 AM
99huggerorangeZ's Avatar
Question wheel spacers
where can i get a set of wheel spacers for a set of 17x9 ZL1s (5 lug, 4.75" lug pattern) for my 1991 RS
will a 17x9 fit a 1991 camaro
clearance problems?
www.aaarims.com
chrome 17x9 w/ red bowtie caps
Old Dec 22, 2002 | 01:37 AM
pu12en12g's Avatar
DO NOT get spacers.
I have 2 SPD adapters for sale. You would need to get 2 more.
"Ideally, you would want some clearance on the inside of the rim to compensate for suspension movement, etc. In this case, we recommend 2" adapters for the front and rear. You can run the 2" adapters in the rear, even though you only need an extra 1.12" backspacing. This will move the wheel further out in the wheelwell, matching the front, and the wider track will help cornering as well. The only time to not match the front adapters is when you have wider wheels in the back (17x11 ZR1's for example). In that case, the wheel will fit in the wheelwell if the 1.25" adapter is used, but will protrude past the fender lip if you have a wider than necessary adapter.
For all fourth-gen rims - 2" adapters front and rear should be used on a third-gen. For C5 and 17x11 ZR1 rims, please do the math!
Old Dec 23, 2002 | 12:46 AM
Question
how much?
got pics?
Old Dec 23, 2002 | 01:05 AM
Question
also do you know what the biggest bf comp ta tire on could fit on those 17x9s?
Old Dec 23, 2002 | 01:19 AM
pu12en12g's Avatar
Make a offer.
They are brand new.
Old Dec 23, 2002 | 11:00 PM
Question
what is spds website
Old Dec 23, 2002 | 11:36 PM
pu12en12g's Avatar
http://www.skulte.com/
Old Dec 24, 2002 | 11:53 AM
caspergotaz28's Avatar
Question
I thought adapters changed the bolt pattern and increased offset.
And spacers just increase offset while having no effect on bolt pattern.
Must be a terminology thing.
Old Jun 19, 2003 | 07:49 PM
pu12en12g's Avatar
Adapters CAN also change the bolt pattern.. yes. And they most definately increase offset.
Old Mar 25, 2004 | 11:22 PM
fullcollapse's Avatar
im diggin in the past here but if you still got those wheel adapters ill give ya 120 shipped for them...
corey
force10
Aug 10, 2015 08:30 AM
Slayer
Jul 4, 2015 03:06 PM
BLK1997Z28
May 2, 2015 01:26 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
derty
Aug 31, 2002 12:28 AM
