My stupid speed limiter with 410 gears!!!
Old Dec 21, 2002 | 08:39 PM
PullmeOverRed's Avatar
I have a 98 v6 auto camaro that had a speed limiter set at 109. but since i added 410 gears the stupid things kicks in at 90 now. hypertech doesn't make anything and the scu2000 will not work with 410s. i was thinking of finding a computer from a wrecked camaro to see if that would work. what do you guys or girls think i should do.
Old Dec 21, 2002 | 09:55 PM
V6 Punk 93's Avatar
Buy this: Jet SCU2000
Old Dec 21, 2002 | 10:17 PM
Marky82's Avatar
4:10's wow.....just out of curiousity what made you put those in a V6.......is your car really modded?
Old Dec 21, 2002 | 10:42 PM
MustangEater82's Avatar
I thought the hypertech thing did...
ohh well I haven't tried it but in theory hooking up a toggle switch to the VSS sensor you may be able to unkook your speedo, everytime you swithc it off... Your speedo will ot work, not sure if it will cause other problems or not.
But in theory it will work.
Old Dec 22, 2002 | 05:06 AM
1fastV6's Avatar
you would have to find a computer that was programmed for 4.10s and i dont think that will be easy to do. what about http://www.superchips.com? i really dont know though.
and even if hypertech did make a 98 V6 model it would not cover 4.10s. i bought it for my 3.73s and it does not program for 3.73s. luckily it does program fo 24 in high tires, which put me in the same ballpark with the speedo. but how weak is that- you would expect it to reprogram for 3.73s or 4.10s. why would i go from 3.42s to 3.08s? which is what it will program
Old Dec 22, 2002 | 07:36 PM
NovaScotiaRS's Avatar
Have you checked with a GM dealership. It is a longshot but they might be able to reprogram for gears. I know they cannot/willnot reprogram for revlimit/speedlimit.
Derek
Old Dec 22, 2002 | 09:43 PM
V6Power's Avatar
Jetscu goes up to 4.10s. I had one but couldn't get it to work at all. Your best bet is pcm programming though.
Old Dec 23, 2002 | 09:46 AM
the camaro with 410s did you have a speed limiter and if you did how did you get rid of it????
Old Dec 23, 2002 | 12:07 PM
Green G0blin's Avatar
that jet chip you guys posted was only for 96+..mine is a 94..how can i get one for a 94?
Old Dec 24, 2002 | 12:21 AM
V6Power's Avatar
94 has OBDI, which has been hacked up and down the street. Do some searches, I haven't looked into it myself, but there are plenty of people who can help you out. Make a post here in the LT1 section about OBDI programming.
Old Dec 24, 2002 | 11:25 PM
99blackSS's Avatar
4.10s on a V6 auto! I am considering putting 3.73s on the A4 LS1.
Old Dec 26, 2002 | 12:07 AM
fourthgen9534's Avatar
i've got a switch on my vss........works, according to online calculators, i got up to around 123-124, ran out of room, but it wasn't climbing very fast. don't know how fast i could actually go.......rambling, sorry.......but yeah, the switch works, and takes less than 20 min to do
By the way, what do the 4.10's feel like
Old Dec 26, 2002 | 10:19 AM
what is a vss? and if you have a speedo reclibrator..where did you get it.....and for how much.
Old Dec 27, 2002 | 10:59 PM
Hey, any of you automatic 98s not have a limiter because i can use your vin number to reflash my computer to get rid of mine so if you don';t mind sharing you vin number i could get rid of my limiter.
Old Dec 28, 2002 | 03:35 PM
djcam's Avatar
all u v6 guys, i have ridden in PULLMEOVERRED's car and 4.10's are the PERFECT gear for the v6's. dont waste the money on 3.73's. if u can figure out the speed limiter thing, 4.10' s are GREAT!!!
