VSS not working
Old May 21, 2008 | 11:27 AM
BMX Dad's Avatar
VSS not working
I swapped out transmissions from one 1995 F-Body into another 1995 F-body last week.
After the swap the speedo did not work and the trans was not shifting properly.
I then swapped the VSS off of the original trans because it worked before the swap and I still have the speedo and shift problem.
With the car in neutral and the ignition on, there appears to be no current in the wires going to the VSS. Is that normal?
What should I test next?
Old May 24, 2008 | 01:04 PM
OBE1 95Z28's Avatar
Verify the connect and harness didn't get damaged during the swap.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
