Question about 95 formula stock drivetrain
Old May 15, 2008 | 05:50 AM
Billy Biker's Avatar
Question Question about 95 formula stock drivetrain
I test drove a 96 Z28 6-speed convertible back to back with my 95 auto formula when I was debating which one to buy. The Z28 had some mods...I'm not sure what all, but I know it had a diff exhaust and some diff gauges inside. Never lifted the hood cause I wasn't quite that serious about it yet. But the formula was stock, and it was quite a bit faster than the Z28. Mileage was close to the same...but the Z28 didn't have reverse, and seemed a little bit rougher than the formula, and of course was more spendy. But what really sold me was the diff in acceleration..I figured the 6 speed would be faster. That brings me to my question. My formula is an extremely strong running car for stock, and just lately I've been starting to wonder if somebody swapped rearend gears in it. It seems to have a slight bit of rearend slop, more than a 90k mile car should. Between that and the way it pulls I'm wondering if its been geared down. The speedo's always seemed to read a little high compared to our other cars and traffic in general.....at 70mph I'm turning 2000rpm's...at 65 I'm turning 1800...at 60 I'm turning 1600. Are those consistent with stock gearing for my car? Tires and rims are all stock size. It gets great mileage...so if its geared down it hasn't hurt fuel mileage much if any.
Old May 15, 2008 | 06:05 AM
MTBSully's Avatar
im not sure about those numbers but a good way to test is to get a car that you Know has a stock gears/tires etc. Go like 5 miles in it and clock it on the trip, then do the same trip in your formula and make sure it is 5 miles too. Thats what i did with my formula
Old May 15, 2008 | 10:28 PM
Those numbers would correspond roughly to a set of 4.10's. That assumes stock tire diameter, and that the PCM has been programmed with the correct rear axle ratio. With stock 3.42's, you'd be at about 1,600 RPM at 70MPH in 6th gear.
Jack it up, rotate the wheels exactly one turn, and count how many times the driveshaft turns.
Old May 16, 2008 | 06:01 PM
Actually those numbers are from my 95 formula which is an auto. Should I still be turning around 1600 at 70 in 4th with stock gearing?
Old May 16, 2008 | 09:11 PM
dan22q's Avatar
You have 2.73s. If your speedo is even close you right.
(If it wasn't you would know it)
cmdeshon
Jan 4, 2015 11:15 AM
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
