help with rear brakes!
Old Apr 15, 2008 | 06:45 PM
Hark_z's Avatar
I'm putting the new pads in and they don't fit over the rotor. Can you push the piston in on the rear the same way as the front with a C Clamp or not? Dont want to hurt anything! Thanks!
Old Apr 15, 2008 | 08:24 PM
williamfvc's Avatar
It is a little hard to put a new fat break pads, but if you buy the correct ones with a little work you can do it. Yes i compres the piston with a clamp.
Old Apr 15, 2008 | 09:52 PM
Green96Z's Avatar
Yep, works the same way. Just uncap the reservoir, drain a little fluid if you're worried about overspill, put the OLD inside pad on (the one that clips inside the piston cup) and use a big C clamp to compress it.
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
