Thrust bearings and coil overs
Does anyone know if these bearings will fit the QA1s on the front of a fourht gen? I do not have them on there know and they are a pain t adjust.
http://store.summitracing.com/partde...5&autoview=sku
Thanks
scott
Thanks
scott
If you don't keep those bearings clean they will be useless real quick. Use a dry spray lube, otherwise if you use any wet lube it will attract a alot debris. Wet weather "Fs "them up the most.If you are adjusting your ride height quite often, then yes there probably worth it, If not don't waste your hard earned money. IMO!
I finally removed them them on my 2nd coilover setup because they cloged up and rusted.
Now with out the bearings I just spray some dry lube around the bottom of the spring, and on the treads above / below the spring seat before adjusting. Then it's not to hard at all!
Sergio
Jan 27, 2016 04:27 PM
guionM
Sep 5, 2002 09:20 AM
