Tie rod bushing blown out and play in the a arm
Old Mar 28, 2008 | 12:58 PM
Critter's Avatar
Today i noticed the pass, front tire if you grab is you can shake it a little. I looked closer and the tie rod bushing is blown out and i think the a-arm is wiggling some too. I have no experience with suspention at all. I am the typical spend money on the engine, drivetrain, and tires but nothing on suspension. Is there a write up on how to check this stuff out to make sure i'm not tearing stuff up and causeing more damage? Also how can i know what needs to be fixed on it?
Thanks in advance, critter
Old Apr 2, 2008 | 12:16 PM
bluz28's Avatar
If the pass. tire is not worn noticebly more the the drivers side, and the car drives straight (doesn't pull to the left or right).Then first, just replace tie-rod ends you know you need. And hopefully that gets rid of the play.
If not, are the bushing and balljoints factory original from 94(never been changed)?
If the are there probably wornout, and need replacing.
Also check the wheel hub for play.
Jun 6, 2015 08:27 AM
KYWes
May 22, 2015 08:48 PM
akwa
Apr 5, 2015 05:09 PM
KYWes
Apr 3, 2015 07:59 PM
Hurin
Dec 13, 2014 07:38 PM
