torque converter will not lock
Old Mar 23, 2008 | 04:54 PM
whitelightning93's Avatar
1993 a4 formula
torque converter will not lock at all fluid is good and it is all stock and throwing no codes
Old Mar 23, 2008 | 10:00 PM
12SCNDZ's Avatar
Um...the most obvious is often overlooked. Check for a blown fuse. Have it scanned and see if the computer is commanding lock-up. Many parameters need to be met for the computer to send the command. Bad brake light switch? Bad connection at case connector? Bad lock-up solenoid? Stuck TCC valve? Bad converter clutch?
Frank
CPT
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
