putting a new rear end in
Old Dec 14, 2002 | 03:03 PM
94TeALFiReBiRd's Avatar
Exclamation putting a new rear end in
ok i have a 94 firebird 3.23's non posi.... i will be putting in a 95 z28 3.42 posi rear end with disc brakes and TC... what extra stuff do i need to do and what are the steps to taking the axle out and putting the whole new rear end in??
Old Dec 14, 2002 | 03:25 PM
blue95's Avatar
I believe its just a longer brake cable since you are going to disk brakes.
Old Dec 14, 2002 | 10:49 PM
eyeoutthere's Avatar
With the exception of needing a longer e-brake cable, it should just bolt in.
However, when I had my V6, I wanted to do the same thing but for some reason people told me not to buy a rear-end that had traction control. Which may cause some problems because it requires a computer to work, and the traction control cars my have a different ABS setup. Check with the LT1 guys.
Old Dec 15, 2002 | 12:20 AM
Slowmaro1988's Avatar
you will need a new master cyclinder if your going from drums to discs i do believe. just get a 100$ SLP posi and make yours posi.
Old Dec 15, 2002 | 01:23 AM
well the reason i am doing this is .. its a great deal..... im only paying 200 for eveything.... and i jsut dont want posi i want some higher gears too..... the car this is coming outta only has like 50,xxxx on it.....
Old Dec 15, 2002 | 04:33 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
are you going to keep the brakes, i thought jeremy was going to buy them,
if you do get the brakes , you will need a new proportioning valve in addition to the rear brake lines , and e-brake cable
Old Dec 15, 2002 | 04:45 PM
im not really sure yet..... it will be some time before he gets all the stuff outta the car...
Old Dec 15, 2002 | 09:01 PM
chesee48's Avatar
hey brotha,,,sorry to bust in in your post...
are u still selling the rksport ****? ivebeen waiting your reply
email me!
chesee48@aol.com
thanks
Old Dec 16, 2002 | 02:33 PM
MustangEater82's Avatar
I did this swap...
First off... you do not need a new master cylinder or brake proportioning valve... I have had mine with niether for over a year, and they stop much quicker then then my drum brakes ever did. I have autocrossed and road raced on them.
As for e-brake cable you jsut need the left and right one off a z28 or a 4-wheel disc brake v6 from 93-97, which is pretty rare I think y87 only.
I did it in a parking garage with 4 jackstands... a hydraulic jack and the stock spare tire jack.
Get a big breaker bar for the bolts.... I didn't have one.... made things difficult but I posisotn the wrench above a jack so I could "jack " some bolts loose to be taken off.
I suggest taking off the entire rear axle along with the torqu arm and drive shaft connected. Its really really hard to get the stock 2 piece driveshaft off the torque arm wqhen it is all on the car but once off the car takes less ten a minute to do.
Along with taking hte old driveshaft out i woudl defiently upgrade.... go for ls1 if you can afford it unless you are like me and canot I got a used Lt1 Driveshaft for $25.
when you rebleed the brakes.... use a clear bottle and a lawnmower fuel line(any car store has them, its a clear tube0 and bleed the brakes till you see the air gone.... keep doing it over and over till when you dirve the brake feel solid. I know a couple peopel have had problems and rebled their systesm like 3-4 times it took me 5 times to get it right.
I can get mopre specific if you wnat or can answer any questions you have.
my AIm is in the sig....
Old Dec 16, 2002 | 04:38 PM
thanks for the info..... so ill just to bleed the brakes and get some new brake line then..... and the e-brake thingy..... and what about the TC system????
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
