sbc oil pan on lt1?
Old Feb 18, 2008 | 08:31 PM
greenmachinedriver's Avatar
sbc oil pan on lt1?
has or is anyone running a sbc oil pan on a fourth gen with stock k-member? i really dont care about the low oil level sensor and dont really want to spend the $$ for a canton. i will be running a 383 with a high volume pump and would like the extra cacacity of the aftermarket pans. any info on this subject would be very helpfull.
Old Feb 18, 2008 | 08:40 PM
rskrause's Avatar
It would have to be a 2-pc rear main seal pan. It would then fit on the motor as the LT1 is just a Gen 1 SBC from the deck down otherwise Would it fit in the car? Probably not. Would it be cheaper, comparable quality to quality than one that is designated to fit? Probably not.
Rich
Old Feb 18, 2008 | 10:54 PM
i belive it would haveto be a 1 pice rear main seal pan tofit seeing an an lt1 is a 1 pice rear main. i know they will fit the block withoout problem but what about the chassis? anyone done this before?
Old Feb 19, 2008 | 06:33 AM
rskrause's Avatar
Of course, it is 1-pc. Sorry. I don't know of any that would fit, but you could take some measurements and see.
Rich
Old Feb 19, 2008 | 10:41 AM
96m6lt1's Avatar
pan for a 1 piece rear seal will work(f-body)
if you buy a pan for an 87-92 f-body you can use it,you may want to mod it so the lo oil level light will work..
Old Feb 19, 2008 | 07:40 PM
have you personally had experience witht this? not doubting you but i want to make shure someone has done it before i order a pan.
Old Feb 19, 2008 | 09:33 PM
Formula408's Avatar
I have a friend running a milodon 30909 stroker low profile pan on his 383 lt1 right now with a stock k member. In fact I have one to go on mine if I ever get it done. So yes that pan will work but fair warning its as much as other lt1 pans anyway but is stroker clearanced and has I think a little extra capacity.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
