Calibrating tach when switching to 155mph speedo?
Old Dec 13, 2002 | 08:15 PM
firebirdude's Avatar
I know this has been mentioned many times before, but I can't find the answer I'm looking for using the search feature.
If I swap out my 120mph cluster for a 155mph cluster, the actual speedometer will read correctly, right? But the tachometer will be off, right? How do I get it to read like a V6? I remember somebody mentioning that all that has to be done is to put a small capacitor or resistor in-line somewhere and it will read correctly. I know Dakota Digital has an adaptor but if I can save some $$$ I would like to. Anyone have any other ideas?
Old Dec 18, 2002 | 06:13 PM
stangkilla1's Avatar
The Hypertech 3 claims to re-calibrate everything from gear ratios to speedometers to rim changes. Check into it, it might handle the tach too.
Old Dec 18, 2002 | 06:22 PM
ibanez6rg's Avatar
That is, if you don't mind dishing out $300+
Old Dec 19, 2002 | 08:52 PM
And I do mind! I have heard there is a simple way of doing it.... just can't remember exactly.
Old Dec 19, 2002 | 09:26 PM
ibanez6rg's Avatar
Well then good luck to ya!
IndyZman
Oct 22, 2015 02:17 PM
4586
Sep 27, 2015 01:55 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
mmf_1013
Sep 12, 2015 08:56 PM
jackpawt883
Sep 10, 2015 08:53 PM
