Stock or Performance
Old Jan 30, 2008 | 12:38 AM
KingJames's Avatar
My fuel pump went out on my 2000 V6 3.8L Camaro, and now I'm searching around the world for one that will fit a V6. I was wondering should I replace it with a performance pump such as a Walbro high pressure pump or with a stock one like a AC delco. If I should go stock, does any know a good pump I can get that's NOT $300??!?! Thanks.
Old Jan 30, 2008 | 08:03 AM
2000GTP's Avatar
For the GM pump, was the quoted price for the pump itself, or the entire drop in assembly? A high flow aftermarket pump would probably run you around 130 bucks. You could also try a GM wholesale parts supplier and might have more luck finding a GM pump cheaper. http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Jan 30, 2008 | 11:46 AM
KingJames's Avatar
^Yea, I tried that link before and called, they didn't have the part for my model. I'm just asking should I replace the old fuel pump with a stock or performance pump, and from where for a good price.
Old Jan 30, 2008 | 12:17 PM
2000GTP's Avatar
You could go either direction, its not going to really matter. The performance pump would at least make a good base for any future mods if you went that path.
Old Jan 30, 2008 | 02:41 PM
KingJames's Avatar
U know any good sites to get a fuel pump for the 3.8L V6? I think I'm gonna go ahead and go with the performance pump. Which will last longer?
Old Jan 31, 2008 | 08:45 PM
camaroLevi's Avatar
here ya go i have a 2000 3.8 as well , this place is the cheapiest and has many varities to choose from , and they do core rebates as well http://www.rockauto.com/catalog/x,ca...,parttype,6256
Old Feb 2, 2008 | 12:58 PM
KingJames's Avatar
Yea, I think I'm going to go with the performance Walbro pump from APE. Think I'm going to get the LT1 Kit from there. It's a good price for a good pump. I was going to go with the Racetronix plug and play but this maybe just as good for a better price, plus they use the same pump.
Old Feb 2, 2008 | 01:29 PM
2000GTP's Avatar
Yep, the Racetronix is just a rebadged Walbro.
Old Feb 5, 2008 | 06:19 PM
Revolutionary's Avatar
I just replaced my pump recently and found a pretty decent deal at Partsamerica.com which is the online version of Advance Auto Parts. I paid something like $228 and drove to a local store to pick it up and saved $50 over what the local store wanted to charge.
Looking closely at the pump it looked exactly like the OEM pump (number stamping and stickers) so I am pretty sure it is a reboxed GM pump. It put out enough fuel for me to go over 120 this weekend...
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
