Shift Lever Solenoid????
Old Jan 22, 2008 | 08:31 AM
DEEZ-Z28's Avatar
My Z28 (95) Lt1 has recently been giving me problems shifting out of park. Once out of park it shifts easily through the other gears. Is this due to a faulty Shift lever solenoid? If so how easy is replacement and where might I find instructions on how to check and replace if neccessary?
Old Jan 30, 2008 | 08:03 AM
01Z's Avatar
01Z
Since I'm browsing this section I'll bump your thread to the top again to see if someone will/can answer your question.
Old Jan 30, 2008 | 10:15 AM
Bayer-Z28's Avatar
I'll take a stab it this. I had an 85 Firebird w/ an auto..
Take the shift boot off and snoop around.. I believe the button is connected to a rod that releases the shifter from the park position.
EDIT: Wait. You can take the shift **** off with a flat screwdriver by popping the hose-shoe clip toward the front that holds it down, FWIW... There's a rod that goes down thru the shift LEVER that controls the lock underneath.
Again, not exactly sure. I'm pretty sure that's the only thing that prevents it from going into/out of park.
Jeff1904
Jun 5, 2016 05:00 PM
WobblySausage
Oct 7, 2015 10:09 AM
marlar98
Sep 19, 2015 07:53 AM
Aaront810
Sep 11, 2015 11:24 AM
jackpawt883
Sep 10, 2015 08:53 PM
