5.3 help
Old Jan 22, 2008 | 06:11 AM
supernova1972's Avatar
5.3 help
This isnt and f-body lsx tech question, so if its the wrong forum move or delete please. I have a 2000 z71 as my dd. 5.3, a4, 4x4. SES light came on and it was the code p0332 for knock sensor problem. The light came on while driving at about 40 or so. Not on start up. I will probably change the knock sensor but is there any other problems that may cause this code that are comenly known?
Old Jan 22, 2008 | 12:01 PM
jay_lt4's Avatar
on the trucks i have seen with that code, usually moisture gets down in the knock sensor holes (there are 2 knock sensors) and causes problems,, you will need to remove the intake manifold and check the knock sensors and harness for damage
Old Jan 22, 2008 | 12:09 PM
Gripenfelter's Avatar
Water will do it.
Otherwise measure the resistance of the sensors. It should be around 100 ohms or so.
They also have to be torqued down properly.
Sometimes the sensor gets loose either from the motor or the harness.
Old Jan 22, 2008 | 09:23 PM
Kraest's Avatar
Retired
Surely will
fift5
11
Oct 1, 2015 10:31 AM
detroitmuscle
Jul 31, 2015 04:21 AM
Teal84z28
Feb 18, 2004 10:53 AM
VentsWoker
West South Central
Aug 28, 2003 11:36 PM
VentsWoker
Aug 28, 2003 10:10 AM
